Update On Oil Lubrication >
Old 02-24-2011 | 07:12 PM
Audiofn's Avatar
Charter Member #232
I have not seen the 15/50 at Walmart for a while. I keep checking. Last time I saw some was 2 jugs back in october.
Put your best foot forward!
Audiofn is offline
Old 02-25-2011 | 07:22 AM
Default Mobil 1 V-Twin
I have been using Mobil 1 V-Twin in my 496 HOs
since the boat was new. Great stuff! I send samples
to Blackstone each oil change. I have about 270hours
on the engines and there is virtually no wear.
Thanks Hydrocruiser!
myturn is offline
Old 02-25-2011 | 07:33 AM
Rage's Avatar
Default API SN Rating
this explains the SN rating. Note the warning for flat tappet lifters.
http://www.aa1car.com/library/api_mo...ifications.htm
Rage is offline
Old 02-25-2011 | 08:23 AM
Rage's Avatar
Explaination of the API ratings from the API web site:
http://www.api.org/certifications/en...010_120210.pdf
Explaination of the API ratings from Royal Purple
http://corvettes.about.com/od/basicm...ur-Oil-Can.htm
Pretty clear that high ZDDP is a must for flat tappet cams but a "nice to have" plus for other applications per the comments.
Rage is offline
Old 02-25-2011 | 08:47 AM
http://www.goldenmotorguard.com/cart/
Lots of zinc.
Ken
minxguy is offline
Old 02-25-2011 | 09:24 AM
Rage's Avatar
Default ZDDP Additives
A number of articles mention ZDDP additives that one can add to the oil. What ZDDP additive products are available? Where can they be purchased. Pros and cons of stand alone ZDDP additives?
Rage is offline
Old 02-25-2011 | 06:00 PM
I would not recommend ZDDP additives. Oil manufacturers spend multi-millions of dollars on their formulations, and if you change the "recipe" by adding more zinc to a product that is formulated to not have it, you can cause foaming of the oil. Too much zinc will cause foaming therefore leading to reduced protection. Would you add an extra egg to your grandmothers famous cake recipe, because you thought it would be better?
07DominatorSS is offline
Old 02-26-2011 | 05:30 PM
Hi can any one please tell me wot Donaldson # filter would fit the merc 496ho thankyou
paul buckner is offline
Old 02-27-2011 | 08:14 AM
outriggers's Avatar
Default Zinc
Since they removed some of the Zinc, I have used this in anything I am concerned about. My oil of choice in the boat is Mobil 1 V-twin, with a Wix racing filter. http://www.cam-shield.com/ Their site is informative. Not for use with anything with a catalytic converter. Doug
outriggers is offline
Old 02-28-2011 | 08:00 AM
Based on what I found in other threads the 496HO will use an AC-PF1218 which crosses to the Amsoil Donaldson EAO24. Give me your Merc part number and I will verify that this is correct. If you can tell me how much room you have below the filter, I can see if they have an oversize that will fit in it's place.
ThisIsLivin is offline
