-   -   steering (https://www.offshoreonly.com/forums/general-q/24694-steering.html)
H2Xmark 05-19-2002 11:12 AM
steering
Well i have a question, how do i straighten the steering wheel on my baja h2x, it is cable to factory hyd. internal steering, the wheel is a quarter turn to the right, any info on this? thanks Mark
cat n around 05-19-2002 11:47 AM
Make sure the drive is where the boat goes straight take the bolts out of the steering wheel set it on straight put bolts back in ,that should do it
H2Xmark 05-19-2002 09:26 PM
sounds easy enough, thanks, I did not know if you adjusted the cable or something else on this setup
