cross overs /thermostats why?
Some talk on crossovers,,, leads me to the question. Why do some motor builders when pro or supercharging an MPI motor like to leave the thermostat out all together?
They say they recalibrate the ECU to not run in a rich condition when seeing a cool engine... I would guess the motor would run in the 120's instead of 160.. They say a cooler motor is a happy motor but at what temp do you cause issues with ring seal etc.. Just a topic for discussion...for you motor heads:drink:. |
the ones who try to run no therm aka procharger is merly a bandaid to fool the ecm into richening the mixture..a B/S way of trying to get to run rich enough without the costly reprogram of the ecm. if you run a crossover(which I did) with no bypass and therm will run way to cold to get rid of moisture in the oil...you need about 150 to get it cleaned out..
Would you be saying that if you ran without thermostats, your oil temp wouldn't get too hot??
I'm asking because on my boat, as I got it from the seller, (with twin 454 Mag's) is running crossovers and it wasn't running any thermostats or oil coolers... |
Originally Posted by ezstriper
(Post 3320071)
The ECM is actually switched to an MEFI 4b which will allow you to control fuel based on boost pressure and programed not to run rich because of temp.. Is 150 the point at which moisture or fuel is removed from oil..? Leaves one to ponder...:drink: |
Originally Posted by silent lucidity
(Post 3320283)
From what I understood the oil temp does come up to a safe level but the motor just runs cool all the time getting rid of all the extra heat generated by supercharging..
The ECM is actually switched to an MEFI 4b which will allow you to control fuel based on boost pressure and programed not to run rich because of temp.. Is 150 the point at which moisture or fuel is removed from oil..? Leaves one to ponder...:drink: That might sound stupid - but that is my goal normally..... |
Any more info? I am running crossovers and considering changing to ones with a thermostat setup. I never build any water temp, but get plenty of oil temp if I run hard. I wonder if adding t-stats will push up oil temp into unsafe range?
Originally Posted by hotjava66
(Post 3320300)
I would like to add then to my twin 454mag mpi's but have concern as to what the right set up would be.. With or with-out thermostats,,,??? My biggest concern without is the on rush of cool water into a hot motor and causing cracking of heads, etc.:eek: |
(Post 3320541)
I run an open crossover with an oil thermostat. Water temps NEVER get over 120ºF and I never have problems with condensation in oil. |
I ran mine both ways..when I got the boat had a crossover, no bypass no therm, ran to cold, oil temp stayed to low and had condesation bad in the valve covers. changed to a crossover with a bypass and a 140 therm with a couple of 1/8 holes drilled in it..now runs constant 150, oil temps good, no condinsation and picked up fuel economy in the cruising range....
The main advantage to running a crossover without a thermostat on a supercharged engine is that it keeps the heads cooler and lessens the chance of detonation. Also, the cooler temps increase mixture density and that results in more power. And, of course, there's so much stuff on the front of a supercharged engine, it's just easier to plumb.
| All times are GMT -5. The time now is 07:50 AM. |
