Plunbing procharger intercooler
what is the best way to plumb the water for the intercooler ? just redoing mine and it's tapped off the crossover, was not sure if that was the best set up or not ? thanks Rob
We installed a thruhull pickup on the bottom and ran it straight to the cooler then out the side. Plenty of water when you need it and no strain on the rest of the cooling for the engine.
Fixx
through hull pick up ran through a sea strainer so you dont plug the orifices in the cooler and a pressure relief valve..then you dump the water out the side the steering wheel is on so you can keep a eye on water flow..a water pressure gauge can be installed as well..
Originally Posted by mrfixxall
(Post 3326792)
You do not want big water pressure through the intercooler, it will damage the internals.....:eek: |
As mentioned, add a seperate pickup and force feed the intercooler. You don't need water flowing at idle when the boat isn't moving. Once on plane, it will force water through the intercooler. You also don't rob any water from the engine. It needs all it can get usually.
Some will dump out the side where you can see it and some dump it through of the transom on top of the drive for additional cooling. Eddie |
how about a pickup off the transom ?
Just curious, which intercooler are you running ?
I have no idea...polished mounted to the floor...bought the boat like this taking it apart fixing all the B/S putting in a H/P500 carb and setting the procharger up on a blow thru carb...
Fixx
Originally Posted by ezstriper
(Post 3327189)
where to buy the cooler,go here,http://www.frozenboost.com/index.php...88a481808,they are way cheeper then procharger.. |
Young Performance plumbed mine the way he mentioned. I first did the plumbing as prescribed by Procharger. It worked ok but when I ran in cold water, the charge would get so cold I would get condensation on my intake. Even though it was a Cent blower, it would still lope. A few years later, I took the setup to Eddie for a major rework. He ran the cooler off the drive pickup and the engine from a transom pickup. We dumped the cooler on the drive (I already had a through hull there). It works great.
In the end, I went with a cooler like Fixxal mentioned from Frozen Boost. Eddie rigged it to my firewall. It was WAY cheaper than a new cooler from Procharger and works better. |
| All times are GMT -5. The time now is 04:08 AM. |
