Bell housing drive coupler???
Just got the new motors in and they were set up for speedmaster 3's.
I want to use Bravo drives for the time being and I was told there is a coupler that hooks up to the bell housing used on the 3's that converts the application for Bravo set up. Does anyone know where I can find this coupling adapter or what the proper name is for it? Thanks! |
Fixx
Originally Posted by CAPTAIN CHUCK
(Post 3326971)
Originally Posted by mrfixxall
(Post 3326984)
all you need to do is remove the ssm stuff and add your bravo couplers and bell housings and possibly the flywheels if the starter ring is towards the rear of the flywheel.make sure if you have o change the flywheels they are balanced the same,,you will also need to put your engine mounted starter on and the oil cooler then drop them in and check engine alignment..
Due to rerouting oil cooling and the fact that the bell housings on the motors are brand new and I don't have the bravo bell housings to replace them I really want to try to find these couplers I have been told about. I appreciate your input sir. Mr. Gadgets.... Might you know where I can acquire these coupler/adapters? |
1 Attachment(s)
OK. So after lots of digging and searching the wonderful world of the internet I still do not have a definite resolution to this coupler thing.
Here is what I have... |
1 Attachment(s)
Is this the right piece for the job?
I'm getting mixed answers on this so any help is much appreciated. |
Never heard of such a thing. That bellhousing is for bolting a tranmission to. If you put some kind of adapter on there the engine would have to be moved forward. Also the drive plate on the flywheel there is for a transmission. The new coupler appears to be a bravo coupler but it must be used with a bravo flywheel housing which also supports the rear of the engine. This is what you need to use with the new coupler. Maybe I'm wrong but I have never in my life heard of such a thing.
http://www.perfprotech.com/store/ass....aspx#assembly |
That is what I was thinking when I was told about this "magic coupler".
Looks like I'm just going to have to sell the dual cooler housings I have now and get everything for the bravo setup. Thanks for your input Jim. I do appreciate it. |
I can tell ya one thing captain, them bell housings with the dual coolers are worth a "LOT" more than them bravo ones. Seen them bravo ones on ebay for around $100. Your also going to need a couple srarters and not knowing what engines you have possibly coolers.
there is a setup for a Bravo with a drive line. it has a housing that bolts to the bellhousing that allows a driveshaft to hook to it and an adapter that bolts on the ears of the inner transom plate for the other end of the driveshaft. the Bravo drive engages the rear adapter. if that is what you are looking for I can direct you to a picture of the parts although I dont know the number for the kit off the top of my head.
That sounds like something for the forward engine in a staggered setup running Bravos.
that is what it is used for but if you can run a short enough drive shaft it would work. I dont think you could get the engine in the same location as a standard Bravo setup with that bellhousing, I think the coolers and lines would interfere. the only other way would be put the Bravo coupler on that you showed in your picture. it should bolt to the flywheel and if you could get the engine close enough for the drives shaft to engage far enough it would work.
Originally Posted by compedgemarine
(Post 3342530)
actually you would. if you look at the pic of the back of him motor he has front and rear motor plates. it would take time to get it lined up right but it has been done more than a few times.
You could never get the motor close enough to the transom plate with the top mount starters, oil coolers and filters back there. Just wouldn't be practical compared to getting a couple used $100 flywheel housings and being done with it. The boats probably not set up to even use those motor plates.
adding the mounts for the rear plate is easy, I have done it on race boats as a backup in case the ear on the Bravo setup failed. I agree that you probably cant move the engine far enough back which I had said previously but figured I would offer any possible ideas and maybe he can find a way to make it all work.
| All times are GMT -5. The time now is 05:03 PM. |
