K Plane trim switch - any ideas where I can source one?
1 Attachment(s)
Trim switch for a Kplane as picture seems to be an ETN manufacturer?
Numbers on body are 8928 and part number 8544K2T34 any ideas where I can get one. I dont have a perfect connection 0.23ohm/20Kohm setting |
CP Performance has (well at least 6mo ago) them. Don't worry about the color. You can pop the rocker button off and swap them when you get your new one. They have both the single pole and dual pole.
cheers - I have 6 connector does that make it double pole - or doesn't it work like that?
yep, double pole. DPDT=double pole double throw
(ON) OFF (ON)= Momentary ON-OFF-Momentary ON |
Just did a search and found this thread.... What is the difference between a Single Pole and Double Pole switch that are both Momentary On - Off - Momentary On?
http://www.keitheickert.com/p-13093-...ngle-pole.aspx http://www.keitheickert.com/p-13092-...uble-pole.aspx I take it both do the same. Is my assumption correct? A double pole has 6 posts while a single has 3? A double pole would be ideal for operating both tabs or drives at the same time? Just trying to figure out what I should buy... Thanks, Jr. |
Yes.
double pole is basically 2 switches in 1 that work in unison. Operates 2 circuits. |
Originally Posted by US1 Fountain
(Post 3683909)
Yes.
| All times are GMT -5. The time now is 02:35 AM. |
