-   -   Another Blower motor combo question (https://www.offshoreonly.com/forums/general-q/248611-another-blower-motor-combo-question.html)
MILD THUNDER 03-02-2011 10:47 AM
Thoughts on this package. Parts, reliability and HP estimates..
Gen V 509CI
Merlin Iron Square Port heads
Isky Tool Room valve springs
Crane gold Rockers
8.8:1 Comp
Cometic head gaskets on ARP studs
JE pistons
Manley H beam rods ARP studs
Forged steel crank GM w/arp main cap studs
Crane 741 Cam on 114*lsa
Morel hyd roller Lifters
871 Supercharger with Intercooler.
Pulleys to say make 6-7psi of boost
:bigbird:
kvogt 03-02-2011 12:36 PM
I'd run 8.4:1 compression ratio
Kris
MILD THUNDER 03-02-2011 01:29 PM
Kris
Hey Kris. Can that be accomplised by opening up the Combustion chambers on the heads?
Back4More 03-02-2011 01:34 PM
What Kris said, but ditch the innercooler and run Aluminum heads. :D
How about some slightly used 557CI Blower motors?
MILD THUNDER 03-02-2011 02:03 PM
This build isnt for me, but for a buddy. Was kinda one of those idea's of running what he already has, but just adding the blower package more or less.
The original plan is 522CI, Merlin block, brodix aluminums, 871's with chillers. He has the blowers, chillers, merlin blocks, cranks, rods, but the dome pistons need to be changed to lower compression. He still needs to buy the heads, intake manfolds, valvetrain, oil pans, balancers, flywheel, etc.
You gettin rid of your motors??? Whats next??????? :drink:
Back4More 03-02-2011 02:55 PM
Might be easier selling the 42 without power... 400SS or something like that.
ezstriper 03-03-2011 07:19 AM
I think it will be fine...
kvogt 03-03-2011 08:07 AM
It's better to change the pistons.
Kris
MILD THUNDER 03-03-2011 08:14 AM
Kris
Gotcha. After talking last night, i think he's gonna continue on with the merlin block/brodix head buildup. just makes more sense.
mike tkach 03-03-2011 08:46 AM
Gen V 509CI
Crane gold Rockers
8.8:1 Comp
JE pistons
:bigbird:
8.8 comp is a little high,if you go with more cam,you can get away with 8.8 compression.keep the chillers,dont exceed 7 lbs boost,dont go over 32 total timing.youd be much better with a good quality aluminum head,less chance of detonation.hp id say app 775-800.good luck with your build.:coolcowboy:
