-   -   Seals for dry throught transom exhaust (https://www.offshoreonly.com/forums/general-q/248694-seals-dry-throught-transom-exhaust.html)
bigboat28 03-03-2011 10:06 AM
Where do you get the seals for dry exhaust that goes through the transom?
FIXX 03-03-2011 11:18 AM
fixx
eddie marine.
http://eddiemarine.com/store/cart.ph...l&p=11434&c=58
cdail28590 03-03-2011 02:12 PM
I bought just the rubber seal from CP Performance and they were only like $10-15.
MILD THUNDER 03-03-2011 02:42 PM
I made my own. I took a old innertube from a semi tire and cut it to fit. went that route cuz i needed custom fit.
BenPerfected 03-03-2011 02:47 PM
We use the tail pipe seals that CMI sells. It doesn't take very long for these seals to stretch and distort so they become relatively ineffective. Does anyone have seal that works better?
Ghostrider 03-03-2011 02:48 PM
CP has the seals and transom rings you need. You should also get a second set of the actual seals while your at it.
I have a spare set of rings and seals but I'm in Australia so that's probably no help to you!
