-   -   cam help (https://www.offshoreonly.com/forums/general-q/248727-cam-help.html)
Someguy 03-03-2011 05:09 PM
cam help
502 750carb vic jr intake hp500 heads stainless marine exhaust std risers
what cams are you guys safely running with sm exhaust with std risers? was planning on running a 500 cam but dont have the cash for the cust risers they sell this year and dont want reversion drama
thanks
dan
jeffswav 03-03-2011 07:10 PM
thanks
dan
Get the long risers and run the cam you want. Call Bob RMBuilder and he will set you us with the correct cam.
1BIGJIM 03-03-2011 08:51 PM
You will need at least an 800 CFM carb depending on the RPMS you plan on spinning it.
I have two stock 502 cams with zeros hours, springs retainers. Cheap if you need one.
I spend the coin and had Bob put together two new cams for my new brand new engines.
