-   -   B&M 250 thermostat housing (https://www.offshoreonly.com/forums/general-q/249068-b-m-250-thermostat-housing.html)
Precision 03-09-2011 12:56 PM
Any help you guys can lend would be great!
I am converting my NA 509 over to FI with a B&M 250 blower. I currently have the oem recerc pump and thermostat housing on my motor.
My question is this, where can I find a recurculation thermostat housing that will bolt on to the front of this B&M intake manifold?
ezstriper 03-10-2011 07:10 AM
not sure on the B&M but the weiand's used a adapter to move the therm housing out from under the blower on their marine units, I used a crossover and a short aftermarket housing and worked fine
johnnykool6 03-10-2011 07:42 AM
I think this is what your referring to (although this is on my truck). Should be able to adapt to marine.
http://i586.photobucket.com/albums/s..._running_2.jpg
ezstriper 03-10-2011 03:00 PM
the one that came with mine moved it foward and off to the side a little...but blower was smaller...I did not use it as the smaller therm housing cleared ok..
Mbam 03-10-2011 05:58 PM
We used to use the housing off the Mercury 800, but it's no longer made.
http://www.mercruiserparts.com/Show_...ND+WATER+HOSES
bcfountain 03-10-2011 07:38 PM
check out cpperformance,i bought one for my tbs-250blower.it should work on your b&m.
Precision 03-11-2011 05:26 AM
I don't see anything listed on their website that is made for recirculation, just crossover.
737jetmech 03-11-2011 10:46 AM
Stainless Marine makes a kit 04-111250 for a 250 B&M . It includes a crossover.To run the stock pump you may have to fabricate a custom housing.
Precision 03-11-2011 10:59 AM
That's what I was afraid of.....
