-   -   Buying a 22' boat, Survey? Leak down? What should be done? (https://www.offshoreonly.com/forums/general-q/249104-buying-22-boat-survey-leak-down-what-should-done.html)
fastscarab22 03-12-2011 02:03 PM
I might have one closer , sent private message
2Slow4me 03-19-2011 12:38 AM
So they did the Leak down test. on the 500 HP
The results of a cold leak down (boat was winterized, so was done cold)
and the results were between 8% and 18%. Nothing leaked into exhaust or intake. Leakage was rings.
What should this motor read?
At what point is it "bad" or just normal wear?
And are these numbers good, o.k. or screaming rebuild!
bcfountain 03-19-2011 11:43 AM
8% would not bother me,18% would.try and get the motor hot.the #s might change
dogturd21 03-19-2011 12:23 PM
For a Survey- surveyors come in many shapes and sizes. Make sure to get one that knows both hulls and engines. Some only do hulls, others only engines- you want both sides covered even if it means two different people. You could have a surveyor do the hull and a mechanic for the engine.
http://www.namsglobal.org/ - been around for a long time
http://www.marinesurvey.org/ this one seems to have far more members.
