unknown source of shake
I recently noticed on my starboard 454 that the crank mounted raw water pump and balancer have a pretty noticeable shake while the engine is running (idle and in gear). The shaking hoses off the pump really made it noticeable as compared to my port motor.
Is this a symptom of a motor about to crap the bucket? |
I'm thinking you lost a spacer somewhere....are all the components aligned and tight? Has a support bracket failed? Is a belt loose?...Maybe it's just a worn bearing? Are the balancer bolts tight?
Just some thoughts, before you spend $$ having a pro hunt it down... |
Originally Posted by ChristianGott
(Post 3347496)
Just some thoughts, before you spend $$ having a pro hunt it down... Thanks for the input. I've never been down this road before. |
| All times are GMT -5. The time now is 03:43 AM. |
