TRS...Where are they most likly to leak?
I was getting my TRS outdrives ready to pull and paint and was draining the lube out and had a small amount of water in one of them,I am going to pull caps and covers also separate upper and lowers and re-do the o-rings, is there any common place these may tend to leak in water?....There was no water in the bellows, Thanks for any information you may have on this,....Fred
Prop shaft.
Gary |
what gary said.
Fran |
Looking at my manual to see where the seal or o-ring is on the prop shaft....do I need a special tool to get to it?....What is the part #?.....Fred
Are the oil seals that are located in the bearing carrier part#26-76868, 2 required the ones?....is it much work to get them out without special tools?....Fred
Fred,
The seals are not imposible to change with drive assembled. I have used an ice pick to poke a small started hole in seal and then get a long # 6 sheet metal screw and use it to pull seal .Be careful not to scratch shft where the seal rides. Rob |
Thanks rws...I'll try that before disassembly of the whole thing,....Fred
I got the seals off the way rws mentioned doing it.....now I just have to figure out what seal cross references it....anyone know?...the merc number is 26-76868....they are a stainless steel seal....Fred
| All times are GMT -5. The time now is 03:53 PM. |
