OK,
where do I buy this new style,I`m fed up with the old style. Thanks. |
if you have leaks you need to machine the lower piece like Eddie young said to stop it from traping the oil...very simple
47EXCALIBUR ,Ok I`ll give it a try,
thanks. |
valve covers
ok guys thanks for the help called keith eickert today 530.00 per set add 150 more for polished. new style double gaskets no leak 2 new sets on the way thanks for the help
Originally Posted by Vinny P
(Post 3351326)
One thing I can almost gaurantee is that they will leak. Mine leak no matter what I have tried. The only way to stop mine from leaking is to run a bead of silicone around them before locking them down. The bad thing about that is you need dynamite to get them back off. So much for easy 2 bolt removing of the covers. :mad:
Best Regards |
Originally Posted by KEPP
(Post 3353715)
Hate to hear you have had some bad luck? I'm not sure how old your covers are? Since purchasing the company we have fixed the previous oversights and all of our 2pc Valve covers feature our latest quad seal technology. All of the Valve cover rails are machined to accept a new silicone base gasket. Which means the covers seal at the bottom, sides and screws and are all pressure checked before they leave our facility guaranteed to not leak. If your interested in new rails give us a call.
Best Regards |
| All times are GMT -5. The time now is 08:17 PM. |
