-   -   bowtie block (https://www.offshoreonly.com/forums/general-q/249749-bowtie-block.html)
toolsinbox 03-20-2011 08:11 PM
bowtie block
does this block require the tiebar connectors for roller lifters ?
it has a 10.147 deck hight so what would be a good crank to use ? Has a 2 piece rear seal.
I just bought this so any other suggestions would be great.
http://i874.photobucket.com/albums/a...enginepic1.jpg
dennis r 03-20-2011 08:18 PM
yes it does, make shure you get the right pistons for it if it has been decked .050
toolsinbox 03-20-2011 08:52 PM
What in the pic shows you that they need the tie bars? and is 10.147 the stock hight for a tall deck?
The other question I have are hydrolic lifters beter than the non hyd lifters? I need some help with that decision.
DareDevil 03-20-2011 09:04 PM
stock hight for Td is 10,200 so this one had been decked !
your best bet is to contact robert medara and have him make you a build sheet with what you want to get out of it !
jeffswav 03-20-2011 09:08 PM
Thats a good block, you can make a 540 ish CI engine out of it. Use a 4.375 stroker crank with .030 over pistons. You will need some tall deck specific parts to make it work, intake, pushrods, ext... You will need the tie bar lifters to convert it to a roller.
Also somone must have milled it down a little, it should be 10.2 deck height. A standard block would be 9.8
