-   -   dry exhaust questions (https://www.offshoreonly.com/forums/general-q/250039-dry-exhaust-questions.html)
endeavour32 03-27-2011 06:10 PM
Originally Posted by STRAIGHTPRIORITY (Post 3361239)
i do have switchable mufflers.... do u think i should not use them? i was more concerned with running in rough water and commin on and off the throttles...
risers are standard gil tails with standard slope.
In case you didn't know, Merc used the Gil exhuast on the HP 500. It used the standard tails and a lot of those engines were destroyed because of reversion. I don't know what the cam specs were on that engine but I don't think is was very radical. If it were me I would extend them back just to be safe!
Griff 03-27-2011 10:54 PM
Originally Posted by smokin' gun (Post 3359021)
ok guys because of my recent motor upgrade i have to go to dry exhaust because of the camshafts in the engines .my motors are 511ci tall decks 9.5 comp. w merlin heads reworked by champion race heads. brodix hv intakes .950 holleys .and comp cams solid rollers 680 lift w a 106 lobe sep .the cam lobe sep is the bad .i have all new gil manifolds and dry risers .my question is can i plug the fitting on the pipe and drill 3 holes in the end to let the water dump as ive seen on others .im assuming the boat may be a little quieter and i wont have to drill the holes in my hull for the dumps .im just guessing at this but hoping it might work and still not pull water up the pipe as they are 42 '' long being a trs app .or maybe someone has a better idea or has been here before .ive added some pics of the pipes as they are now length and the 2 small holes currently in them
How far do the pipes extend on the outside of the transom???? If they extend far enough, you could just cut the ends off.
On my CMI tails, they are dry all the way through the transom and extend about 4" past the outside of transom. Then the ends are baically just cut off. You can see the inner and outer pipes and the water comes out between them. The water never mixes with the exhaust gases.
Griff 03-27-2011 10:56 PM
Originally Posted by STRAIGHTPRIORITY (Post 3359249)
now im concerned.. i have regular bravo gills 112+2 lsa
duration 292 int/ 298 exhaust.
do i need dry? i really dont know alot about cam size
Youy should not have any reversion issues at all.
STRAIGHTPRIORITY 03-28-2011 07:44 AM
i have heard that also..
but they are only 4" from the transom.. is that going to make all the difference?
