-   -   BBC alternator brackets (https://www.offshoreonly.com/forums/general-q/250056-bbc-alternator-brackets.html)
warriorp 03-25-2011 08:39 AM
What are you running out their on your offshore boats?
I went with a Summit 2027 and worked ok for a year on my airboat. The original turnbuckle made out of AL gave up but I replaced with a steel one I made at a machine shop. However, the mounting bracket is cracked now. I would prefer to replace it with a different brand. I have reduced the substantial amount of vibration seen last year by replacing the front motor mounts with a waterwalker version. I know the offshore racers are experiencing the same problems I am having.
Is the bolt pattern on the SBC chevy the same as a BBC for mounting the alternator with a short water pump low mount alternator bracket?
I think this will be better for the vibration and appears to be a beefier bracket:
http://www.jegs.com/i/Billet-Special...205PC/10002/-1
this is what i had:
http://www.summitracing.com/parts/SME-2027/?rtype=10
jeffswav 03-25-2011 05:43 PM
Look on ebay at Dennis Moores page.
warriorp 03-25-2011 08:59 PM
Thanks Jeff. Anyway you could post a link to his store, I was unsuccessfull finding it.
jeffswav 03-25-2011 10:47 PM
http://stores.ebay.com/Moore-Perform...id=p4340.l2563
warriorp 03-27-2011 10:14 AM
thanks jeff
