Eickert Tail Extention
I need to have my current Eickert bravo tails extended so they are dry to the tip. Does anyone have any suggestions on someone that can do this on the west coast of Michigan? I could mail them to someone but I would rather take the boat to the welder so it fits right the first time.
Originally Posted by endeavour32
(Post 3359513)
That sounds interesting.... I might try that!
Originally Posted by blue thunder
(Post 3359671)
I made aluminum inserts for my KE tails that do what you want without any welding. They slide into the tip and seat into the inner tube of the tailpipes. They lock to the end of the tip with 1/4-20 screws and are flush with the end of the tips. Works great.
You're in luck. I have them out now and just about ready to reinstall them. I'll take pics tonight although I am not sure if I can post pics so you may need to give me an email addy.
I can post them on the site. [email protected]
Pictures send E32. They are made out of aluminum. The one end is turned down to size to lightely fit into the inner pipe on the KE tails. I put silicone on this turned down section so water doesn't leak at the seam. You can't see it well unless you zoom way in but the pic showing the insert installed shows the bolts at the end of the tip that hold it in place.
BT |
4 Attachment(s)
Here are the Pictures.
Thanks Blue Thunder |
(Post 3359671)
Nice work btw! I want to do this too, only problem I have is that my tails are offset to the side a bit from the transom tips. I am afraid the rubber water jacket will touch the inner pipe and melt at the bend... |
Yes, the tubing has threads in it. If your tips are offset from your tails I'm not sure you could ever get the inserts to slide into the tailpipe inner tube. It needs to be a pretty straight shot.
(Post 3653626)
Do you have any butterfly type valves in there anywhere to keep water from going up the exhaust? How does she sound? |
I use clamp on rubber flappers to keep backwash out, they are not on in the pics. It sounds like dry exhaust, loud and crackly.
| All times are GMT -5. The time now is 06:08 AM. |
