Cam Choice
Building a 383 stroker (or having one built anyway), and he wants to use an Elgin E1136P Cam. Specs:
C E-1136-P HL-2148 CL-1136PK Int Exh .308 .313 .462 .470 288° 284° 210° 215° 1° ATC 41° BBC 31° ABC 6° BTC 71° RLR 106° Does this seem like the right cam for a Vortec based 383? It has tube headers and the water is not introduced to the exhaust until right at the tip. I am not looking for top performance as much as an engine that idles good and builds good hp and torque up to 4500 rpm's. I don't want to wrench on it at all. Thoughts? |
Is the cam a flat tappet or hydraulic roller? Is the engine carbureted or EFI? What exhaust system? What is the application/weight of the boat. This info will be helpful. Thanks.
Originally Posted by Boat1
(Post 3362696)
What EFI system? Do you have O2 sensor ports welded into the exhaust anywhere?
(Post 3362707)
I am on the fence of just putting an intake and carb on it, and then monkey with the EFI next winter. |
Since the EFI system is the Scorpion you would need to add an O2 bung in the exhaust to allow an O2 sensor to be used to read the air fuel ratio for tuning purposes. The ECM would need to be re-calibrated for a correct fuel and timing map. Shops like Eddie Young or Mark Boos, among others could perform this calibration. Your other choice is to match the components to the Mercruiser package, compression ratio, cylinder heads, and camshaft, then the existing computer tune will work. The MEFI computer will not learn for a camshaft change or other modifications. Good Luck.
(Post 3362752)
1 Attachment(s)
Originally Posted by 36Tango
(Post 3362600)
C E-1136-P HL-2148 CL-1136PK Int Exh .308 .313 .462 .470 288° 284° 210° 215° 1° ATC 41° BBC 31° ABC 6° BTC 71° RLR 106° Does this seem like the right cam for a Vortec based 383? It has tube headers and the water is not introduced to the exhaust until right at the tip. I am not looking for top performance as much as an engine that idles good and builds good hp and torque up to 4500 rpm's. I don't want to wrench on it at all. Thoughts? Just my $0.02 |
Eddie @ Young Performance Marine is not that far away. The money spent on intake, carb, distibutor, coil, wiring harness etc. would likely be more than having him tune the set-up properly. Everything from your current set-up is usable and will support the power, I'd think your cam choice is smaller than the Mercury original. It might be a pain to travel, but do it once and it's done. I'm just saying the current tune in the computer will probably not work well. Another option would be to contact RMBuilder on the board here, give him an acurate build sheet of the engine components, he may be able to re-flash the computer through the mail with Mark Boos. The best is to tune it in the boat. Good Luck.
Fixx
the scorpion ecm 555 is non tuneable,,but that may have changed..
| All times are GMT -5. The time now is 07:19 AM. |
