-   -   Trans fluid? (https://www.offshoreonly.com/forums/general-q/250331-trans-fluid.html)
rob vanharten 03-29-2011 01:10 PM
Trans fluid?
I will be installing my motors back into my 86 357 soon, and noticed when I removed the engine's this fall I lost a little transmission fluid when we removed the transmision lines. Anways just wondering what type of fluid is used in the borg warner units, and how much do they take. Or how do I know they are at the correct level? Just want to have all my ducks in a row before it's install day. Thanks in advance!
RunninHotRacing163.1 03-29-2011 01:18 PM
Type F BIG Daddy :ernaehrung004::ernaehrung004:
rob vanharten 03-29-2011 07:40 PM
Thanks! What about the fluid level. How do I know how much to add?
RunninHotRacing163.1 03-29-2011 07:44 PM
dip stick ????:eek:
FIXX 03-29-2011 07:46 PM
Fixx
Fill and moniter the dipstick when its off,,run it turn it off and chack it hot,,when you fill it dont fill it all the way cold,just to the bottom line then go from their..
FIXX 03-29-2011 07:48 PM
Fixx
Originally Posted by RunninHotRacing163.1 (Post 3363135)
dip stick ????:eek:
us ill boys have most of the answers:drink:
RunninHotRacing163.1 03-29-2011 07:53 PM
:ernaehrung004::ernaehrung004::ernaehrung004:
rob vanharten 03-29-2011 08:04 PM
Nice!!!:) I didn't even realize they had a dip stick. Thanks again:eek:
FIXX 03-29-2011 08:18 PM
Fixx
thay have a twist to them to keep them from falling out whyle under way..unscrew the t on top and pull it out then when done put the stick back in and turn the t on top to tighten it up..
RunninHotRacing163.1 03-29-2011 08:52 PM
Yep unscrew the T-Handle 2 turns and give her a yank and do the same when you put it back in or she'll blow it out and empty the trans and you'll be needin some new clutches faster then a stripper drops her top :eek:
I ain't one to start rumers but i sure think fixall called you a D!ps^!ck :lolhit::drink:
