-   -   Cam didnt make it! (https://www.offshoreonly.com/forums/general-q/25036-cam-didnt-make.html)
jrocket 05-23-2002 12:36 PM
Cam didnt make it!
Have carbeurated stock 502 mag. 242LS Formula Use for cruising mostly, real heavy boat I need a lot of torgue to plane looking if anyone has figured optimum set up, lift,duration,type, preferences like good speed but really not looking for excess. Just a killer idle. Should I be considering changing over from flat tappet to roller? What are benefits...cons I also if it matters am presently running manifolds thru hull due to headers DNFed in spring planning on new ones but due to needing a new top end will probably have to wait:D What will I be expecting for Max output without pushing the envelope?
Thanks, Rocket
Dave F 05-23-2002 09:24 PM
I have an 87 242 LS.
When I first removed the 454/330 and alpha/1.32, I replaced it with a 502/bravo/1.5.
It did 57 mph on a good day. With the HP 500 it did 70 mph on a good day.
I used Chevy head 10101137. Large oval port with lots of work done.
Weiand Team G single plane, port matched to heads.
800 Holley carb.
Cam was an HP500 cam. Crane # 169611. Specs are 222/230 .576/598 110 lsa 105 icl.
With about 9.5:1 it made a little over 500hp.
I used a 23 mirage and topped out at 5200 rpm.
Ps. I'm now Pro Charged with Merlin heads bigger Crane cam and around 900hp. Approx 95 mph.
DAVE
Dave F 05-23-2002 09:26 PM
Oh, I forgot to say that I used CMI exaust.
