Priming Engine with Oil >
Old 04-02-2011 | 08:36 AM
Originally Posted by 598 Formula
I have a 598 going in this year that has not been fired in 3 years. Fogger has been sprayed in it 2 twice a year, no oil in the motor. Should I prime the same way or should I take the dist out and prime it? Engine only has 80hrs on it and dont want to trash the bearings!!
Brad
yank the distributor , well worth the 3 minutes you'll spend
Old 04-02-2011 | 08:44 AM
Registered User
The first time when i repowered i did prime it via the pump.
Every season do you do that? I guess it wouldnt hurt to be safe
bigblue is offline
Old 04-02-2011 | 08:59 AM
the Skater has external oil pumps we just drop the belt and spin it on a drill 3 mins 80Lbs of oil pressure and slide the belt back on , customers boats all get primed and a splash of Lucas & PRO-BLEND better safe then sorry
Old 04-02-2011 | 09:06 AM
Registered User
I like your thinking!!! And yea that would make life super easy with external pumps!
bigblue is offline
Old 04-02-2011 | 11:05 AM
Old 04-02-2011 | 02:41 PM
Registered User
lol all this toasting of martinis and cheersing of beer mugs on this thread makes me want a beer!!!!
bigblue is offline
Old 04-03-2011 | 12:20 AM
g@@se & red bull meself
Old 04-03-2011 | 01:57 PM
We use a pre-Lube engine oiler, when I spring the boat. Easy to use and you don't need to pull the distributor out of the engine.
Attached Thumbnails Priming Engine with Oil-yhst-58082516732612_2153_13722479.jpeg
motorz is offline
Old 04-03-2011 | 02:53 PM
Registered User
Depends on the day! I like my cold beer in the sun on the boat or at the bbq at the end of the day.
bigblue is offline
Old 04-03-2011 | 02:54 PM
Registered User
Looks simple, which i like!! Im going to google it. Whats the link if I strike out??
bigblue is offline
