525's & Northstar 550
Anyone have these two communicating successfully?
I cant get Northstar to recognize two engines. I installed the dual engine gateway, harnesses ans terminators. I understand there is a jumper wire that needs to be removed and plugged. Would really like to get this working this year and understand it to help others. Fortunately havent had any customers with this issue! Anyone do this successfully? Im only seeing data from one engine so far. Thanks |
Originally Posted by Elite Marine
(Post 3366723)
I cant get Northstar to recognize two engines. I installed the dual engine gateway, harnesses ans terminators. I understand there is a jumper wire that needs to be removed and plugged. Would really like to get this working this year and understand it to help others. Fortunately havent had any customers with this issue! Anyone do this successfully? Im only seeing data from one engine so far. Thanks Hi Kirk , I had the same problem on my cmd diesels and vesselview,tried all different harness and no luck called merc and followed there installation instructions still nothing .after installing the new parts cataloque I read the service bulletins and there was one that the can bus have a wrong installed wire ,changed it and there was all data from the second engine ! Maybe something to look at . Bor |
| All times are GMT -5. The time now is 05:51 PM. |
