what % of h.p lost between crank, and prop.
what is the horse power lost % between crank h.p to prop h.p
my liberator has 375 h.p at the prop, just wondering what my 502 omc has for h.p. I have a omc king cobra book that shows a 454 with 370 h.p@ the crank, and 310 h.p @ the prop with 60 h.p lost, and a 460 omc king cobra with 340 h.p @ the crank, and 295 h.p @ the prop with 45 h.p lost... it seems that the more h.p the more h.p lost you have. thanks for any help u can give me. |
As a rule 10%, some drives may have a little more or less loss.
Originally Posted by intimidator
(Post 3369233)
Originally Posted by endeavour32
(Post 3369289)
What kind of GPS speed do you get with your boat? What prop and rpms are you turning at WOT?
(Post 3369303)
i have engine mods done on my boat, my best is 64 mph@5100 rpm the prop I have is 14 1/2 x 20 raker , but I average 63mph...
(Post 3369312)
Is your speed via GPS? If so you have great prop slip numbers!
I'm in Onekama and would let you try my Mirage 21 but I'm pretty sure you would need a differnet hub. I'm sending my prop in to Bret as soon as the lake thaws and I can get some base numbers.
(Post 3369396)
Last summer my best was 64 @ 5900 rpms with a standard Mirage in poor condition. I'm hoping to gain a few MPH going to the Mirage Plus and a few more by having Brett do his stuff.
What gear ratio you running? 1.36?
Originally Posted by redbud35
(Post 3369798)
(Post 3369312)
Not many V bottoms are that low. |
(Post 3370354)
6% according to the numbers he posted. That is impressive.
(Post 3370354)
Originally Posted by jeffswav
(Post 3370523)
Never seen one that low, I am at 9.8% and that is pretty good. Double check your gear ratio, here is a site that may help you out http://www.rbbi.com/folders/prop/propcalc.htm
| All times are GMT -5. The time now is 09:35 PM. |
