Mine was installed straight up.
Originally Posted by WR-1
(Post 3371969)
I am unsure if it was set with a degree wheel or what ..I am buying these from another OSO member and he had the top ends upgraded with these cams and Brodix heads .I will get with him and find out for sure...They are comming with the Gil/Merc manifolds and risers but I was gonna use the stainless marines I had...which do you guys think is better?
I like the SM's also,but since these motors already had Gils I thought I would ask...The Brodix heads and cam combo really woke up these HP's. I may be off on the lobe sep. I will know when I get the cards.
yes .112* not .114*... my fault
What does this cam make with 5psi in a 509 with decent heads??
not sure, I went N/A..but I would think 650-700hp easy with some good aluminum heads..
Originally Posted by Pokher Ace
(Post 3373726)
Those are awesome numbers...with these 741's and Brodix heads with port work etc..N/A 683 & 679..I was impressed..
| All times are GMT -5. The time now is 03:36 PM. |
