Remote oil filter
I'd like to move the oil filter off of the engine altogether if I can (how far can you go?). If possible, I'd also like the filter to screw UP against the cast piece instead of screwing DOWN onto it. Seems like it would make it alot less messy at oil change time. This is for a 383 small block application. Am I stuck with the Mercury setup?
Originally Posted by 36Tango
(Post 3371153)
Just takes more oil. I probably wouldnt reccomend putting it miles away. |
Originally Posted by bigblue
(Post 3371328)
i Think you can put it wherever you want. Mine is on a home made bracket with ss lines. No oem merc setup for me!:drink:
I used this kit and mounted it on the transom wall where I could easily access it. Comes with 8' total of hose, you could add more if going further- just remember it increases your oil capacity so be sure to add more when changing the oil.
http://www.summitracing.com/parts/SUM-G4985/ |
you want to keep as close as possible, you will lose oil pressure the futher the run is...
Originally Posted by Baja_man
(Post 3371553)
Any pictures?
NOTHIN!!! Will snap some and add it when I get em!!!
leave it upside down, it helps filtering....+ no mess if done right. just punch a hole in the top and let it sit over night ...not 1 drop will be left in it for the change next day !
| All times are GMT -5. The time now is 09:03 AM. |
