-   -   500 EFI Fuel Pumps - Formula (https://www.offshoreonly.com/forums/general-q/251008-500-efi-fuel-pumps-formula.html)
txriverrat2001 04-08-2011 04:14 PM
Any idea who's pump are stringer mounted in the Formulas??? Same part # as Merc - yet has a threaded o-ring fitting on both ends. The original pump had a Merc # on it - which has been superceded -and the replacement is the cool fuel pump that uses the 90degree adapter in the cool fuel assy ... on this Formula (and others I've seen) they've moved the pump directly to the stringer ...
Any ideas???
rs
