-   -   help full tip (https://www.offshoreonly.com/forums/general-q/251053-help-full-tip.html)
paul buckner 04-09-2011 01:29 PM
help full tip
Hi all a litle tip that will help when changing spark plugs in tight spaces (twin motors ) push a tight fitting peace of vac/hose over the end of the plug this helps a lot to get them started and you wont drop them hose is nice and grippy and you can twist them all the way in then just finish off with your socket
