-   -   Will a Merc outboard prop go on an Alpha? (https://www.offshoreonly.com/forums/general-q/251112-will-merc-outboard-prop-go-alpha.html)
hopper75 04-10-2011 02:12 PM
I can get a Tempest 25p prop dirt cheap but don't know if it will work on my Alpha gen 2. Do the outboards use the torque flo hubs as well? The prop is located 50 miles away so I can't get my hands on it to verify.
A.O. Razor 04-10-2011 03:48 PM
If it's from a V6, then in should fit fine. I don't recall the Tempest+ being available in any other size.
Is it for your Baja?
picklenjim 04-10-2011 03:57 PM
I believe it will fit if from the larger outboards as mentioned but is is not recomended for sterndrives. It's designed for lighter weight bass boats.
http://www.mercuryracing.com/propellers/tempestplus.php
http://www.jacosmarine.com/new_mercu...s_for_sale.cfm
