-   -   Trim tab switch upgrade wiring help (https://www.offshoreonly.com/forums/general-q/251389-trim-tab-switch-upgrade-wiring-help.html)
citizen423 04-13-2011 10:17 PM
I'm in the process of completley restoring a 1985 Villian II. I have already purchaced a dual leaver throttle shift control from Eddie Marine and I had them install 3 rocker switches in the throttle lever. I currently have Bennett trim tabs installed and I dont want to reinstall Bennett's rocker switch. I'm wondering if anyone has deleted these switches before and if I need a specific relay to control the tabs from my new throttle mount switches. the control wiring on my new throttle shift lever looks to be 20awg or smaller and probably not designed for very much current.
I also toyed with the idea of adding Livorsi trim indicators and can't figure out if replacing the trim tab uppers with the uppers that include the position sensors will wire directly to the new indicator guage.
I hope I can find some one that has made this same upgrade.
Thanks!!
