-   -   powerquest 380 bow lift (https://www.offshoreonly.com/forums/general-q/251522-powerquest-380-bow-lift.html)
halfbuzzed 04-15-2011 08:19 PM
hello, I have a 2000 Powerquest 380, and I am in need of bow lift. Does anyone have the factory x dimension measurement? Or know of problems in the hull that would make the bow ride very low? I have it sitting at a fiberglass shop right now and we are searching for ideas? a little rocker maybe?
FIXX 04-15-2011 08:21 PM
Fixx
what props are you running?? that would make a big diffferance..
halfbuzzed 04-15-2011 08:29 PM
well, i have tried everything i could. 32 bravo 4 blades, 28 bravo 4 blades, 26 hydro 5 blades. None made a difference, fiberglass guy says pad is straight, no hook. so I'm a bit lost
Griff 04-16-2011 01:07 AM
Spin the props in for more bow lift. Stepped hull boats are designed to run pretty flat.
specialk 04-16-2011 08:56 AM
you should ask the question on the PQ forum. there is a lot of knowledge from some of the owners. PQ had a problem with the strakes on the early year step hulls but not sure if that would have any affect on your concern.
jeffswav 04-16-2011 09:31 AM
Flatter can be faster, it takes energy away from forward thrust when you lift the bow. The only advantage to bow lift is less wetted area. Take a look at some of the real fast v bottom boats they all run pretty flat. After I raised my x dim my boat runs flatter and faster. I used to think you had to raise the bow up high for speed, not true.
mainstreet 04-16-2011 11:48 AM
Bought a 2002 380 PQ last fall, owned a 290 for 8 years before this boat. 4 blade 28 props, someone tried grinding on them for better performance. Had BBlades redo them, can't wait to get on the lake to try them out. He added some cup to them. I will let you know how that works out.
Bad Girl 04-17-2011 12:05 PM
PQ issues
Had a friend buy same one new and had same issue. Problem is there was severe hook in the hull and also were not same on each side. He had alot of bottom work done before PQ closed.
Runs very nice now.
Something to look into.
I took the boat out myself in rough water and tried to trim it and thought a propshaft broke or something since it had NO leverage to pick the nose up.
Hope this helps
halfbuzzed 04-17-2011 10:46 PM
that is exactly what it seems like, I'm leaning towards the hook. But i will lay a straight edge on it tomorrow, thanks
