Baja V8 swap
I found a good deal on a 20' Baja with a 4.3 V6. I was wondering if a V8 swap is possible using the same drive. Any info would be great! Thanks
Originally Posted by jfranks
(Post 3380409)
Thanks for the info. What kind of power will that drive handle?
Actually going to a larger engine would require a higher gear ratio change to like 1.50:1. Your gear ratio should be on a plate on the side of the drive. Of course you would also have to have room in the engine compartment.
If it's an Alpha probably 300hp safely. |
A Alpha Gen II will handle easily up to 330hp. It's not the drive but the gear ratio because your going from a V6 to a V8 you'll have more HP and thus with the higher gear ratio be spinning to high of RPM's. Check the drive for the ratio it should be on the side of it usually the right side of the drive on the upper. If you have a 1.50 ratio you'll be fine it'll just be a matter of swapping the motors.
Originally Posted by picklenjim
(Post 3380435)
Originally Posted by Irishtornado
(Post 3380438)
I'm going to see the boat this weekend. I'll have more info on it then. Thanks for everybody's help!
When I first did a similar swap a few years ago, a local marine engine builder told me with a wink to try the 1.84 gear ratio after i did the swap - he was right, the boat is faster with a 1.84 and propped accordingly...
Use what you have first. |
Fixx
A friend of mine had one,,4.3 with a 1.65 drive...check the stringers real good,,bring a socket set and see if the motor mount bolts are tight,,they rot really bad..wouldnt hurt to knock on the stringers also..
| All times are GMT -5. The time now is 04:42 AM. |
