Opinion needed on a 496 cam
This is a friends motor in a single engine 26 foot sleekcraft
The motor started out as a 365 mag motor, upgraded to eagle 496 ratator. compression 10-1 ported rectangle steel heads (really opened up!) single plane intake 850 holley carb full MSD ignition The cam they recommended was as follows Hydrolic roller 610/610 lift 230/242 duration 112 center What do you guys think? |
What exhaust and do you have flow numbers on the cylinder heads after the work?
no flow number right now
The exhaust is the older CMI two piece tube top. No silent choice |
Who's they ?
Originally Posted by jeffswav
(Post 3381433)
Who's they ?
The guy that said it ran good in a car!
Which made me chuckle |
Another quesion, what are your HP goals and how many RPM's are you planning to run?
I just read your post over again. I see its your buddies boat, tell him to call Bob RMbuilder. The car guys dont know s--t about boat engines. |
Dude! I told him to call Bob, he wouldn't listen.
Always talking 600 HP area at whatever RPM it takes. The previous non roller setup ran at 56-5800 I'd rather see it down in the 52-5400 area. Something with more torque, especially with a single engine. |
Compression ended up more like 10.25-1
Let me start by saying I shouldn't say what I'm about to say, are we clear!! Since your friend has no interest in listening to an expert he clearly is smarter than everyone. If he was spinning a mag motor 5800 WOT he was making noise not power, that cam can't support it. A hydraulic roller combo should not turn above 5400 or you risk valve float. The cam he suggests is not large enough for 5800 rpm and needs to be mechanical roller anyway for that rpm. I think what he really wants is a boat he can talk about. He should put a large duration camshaft with a 108 LSA so he has the most knarly idle in the marina, spend his money on a really cool sticker to put on the engine that says 600 HP or heck even more if he wants. The boat will likely barely come on plane and run terrible but it will sound really cool and show great when it is broke down. I'm sure he doesn't need a 3X18 oil cooler, or a quality oil pump, or upgraded fuel system either but it's a suggestion. Let me know when the maiden voyage is, I'd like to bring a cooler and a chair to watch it get on plane. Good Luck.
| All times are GMT -5. The time now is 09:35 AM. |
