are these 454=440 cyclones
these are in a 33 sutphen 1983, mod 440, ser 6181089 and 6181090. valve covers say[ custom built by mercruiser performace products 500hp] theres no cubes anywhere on motors. any idea if theses are 540s or 454s???
Fixx
Originally Posted by AIR TIME
(Post 3383353)
454's 500@ the crank and 440 at the prop..Trs boat? it could also be the 482 that merc built back then,,i believe they were rated @ 500 hp.. |
440 cyclone is a 454. The 460 cyclone is the 482. Everything is the same except the stroke, compression and floating piston pins. Here's some of the specs if your interested.
440 cyclone: 8.8:1 compression Iron rec port heads Aluminum hi rise intake 850 Holley mech sec 4 bolt mains Forged rods, pistons and crank aluminum roller rockers fully polished crank precision angle valve job cam 288/296 lift I .549" E .558" |
| All times are GMT -5. The time now is 01:01 AM. |
