-   -   K-Plane Pin!!! Stuck!! (https://www.offshoreonly.com/forums/general-q/251965-k-plane-pin-stuck.html)
SKRAMER 04-22-2011 06:38 AM
1 Attachment(s)
Taking my K-Plane Plates off. One came off easy. The long pin on the other plate won't move a bit.. Need Ideas on getting it out! Thanks Scott
Bottoms Up 04-22-2011 06:47 AM
Nice pic....
If your serious try a heat gun first hot but not cooking the paint like a torch. Next a simple torch propane no map gas. Heat it up and drive a pin through make sure no one put an e clip in the hinge. It will barely be noticeable if they did.
Next take the whole unit of and press it out with a ten ton press. Done a few but it is usually the eclip.
Audiofn 04-22-2011 07:07 AM
Best thing you can do it to take them cut the pin between each area on the tab that you can get to. Then you can remove the smaller pieces a lot easier.
redbud35 04-22-2011 10:38 AM
I doubt you'll be able to take the transom plate off the boat, if they're anything like mine were. I beat mine through with a hammer and punch. Took a bit to get it moving.
big jing 2 04-22-2011 10:42 AM
slide hammer 7/16 fine female on shaft ..works great
SKRAMER 04-27-2011 09:59 AM
Anyone know where I can get a new pin if I cut it? or destroy it??
ballon78 04-27-2011 09:38 PM
BAM marine, i think in accessories section
northernoffshore 04-27-2011 09:43 PM
I might have 1 for you
SKRAMER 04-28-2011 06:40 AM
Let me know!
FIXX 04-28-2011 11:47 AM
Fixx
+1 with a slide hammer,,hose it down first with pb blaster and they come rite out..
SKRAMER 04-29-2011 06:22 AM
Had to cut the pin and beat the pieces out. after days of screwing around with it.. Glad thats over...
mrv8outboard 04-29-2011 05:32 PM
1 Attachment(s)
Well sorry I am late then. OTC ball joint/u-joint tool work great to press it out. You can also find the cheap ones at Harbor Freight. Just use the C clamp, it has an open end so the pin goes right through.
