Belts for HP 500?
I have tried searching quite a bit, and have not been able to find what the belts are for a HP 500 (carb). Does anyone know this off hand?
I busted a belt last run of last season, time to do them all. I have a 99 if that matters. |
I'm assuming this would be in the owners manual (on my boat in storage.....)?
Take them to a NAPA or a real parts sore and have them match them up. Go goodyear gatorback if you can but any will do. No diff than what merc put on and a lot cheaper(:
The pump drive belt must be a true V belt without the teeth. The tensioner will make it split.
Originally Posted by Poker~N~Run
(Post 3386999)
I think they said $100 for them at the end of last year and it felt steep to me. |
Probably 10 to 15 a piece at part store.
(Post 3388130)
Do you have your engine serial number handy?
Originally Posted by lakematdude
(Post 3388927)
There's a way to find from that? Thanks |
Originally Posted by rlj676
(Post 3389721)
0L60025?
There's a way to find from that? Thanks Also just as a FYI the serial number you posted is missing one number at the end, There should be a "0L" then there should be six numbers after it to find your engine, especially with your engine because it would mean the difference between having a Carbed engine or a EFI engine if your off one number. From what I can tell from the serial number you posted and me guessing a final number, Your engine does not have Power steering? Merc part number 816034 is Superseded to 816034Q $42.78 Description: V BELT, 48.125 LG (Water Pump) Merc part number 812427T is Superseded to 812427Q, MSRP: $47.90 Description: V BELT, 56 LGTH (If you have "Power Steering") Merc part number 69143T is Superseded to 69143Q MSRP: $27.30 Description: V BELT, 40 LGTH (Sea Water Pump). And here is a link to all of your engine parts for you. http://www.mercruiserparts.com/selec...doc_nbr=878389 Hope this helps, Good luck.:) |
| All times are GMT -5. The time now is 11:04 PM. |
