How much boost would you run??
509CI, Merlin Iron heads, 9:1 Static comp, superchiller, 8-71. Cam .237/.248 Hyd roller 112LSA .650 lift...
5,6,7,8 psi??? Pump gas. :coolcowboy: |
Dump the chillers and run 4-4.5
Heads are on ARP studs. I believe they used a FelPro 1037 headgasket, no cometics...They were talking running 8psi, but seems too much with 9:1 and iron heads to me. Dont wanna see my buddy grenede anything. They will be going to the dyno, but i know dyno and boat results can differ quite a bit..
With the 8-71's on those 509's at that CR you not going to make much heat spinning them as slow as needed anyway. By leaving them out you'll idle tons better and lesson the chance of loading up the plugs.
So basically, the chillers offer no advantage unless say you are overdriving the blower alot? He planned to rig it where the chiller doesnt get any water flow at idle.
The 9:1 with iron heads kinda scares me when talking 8psi on pump gas. Also, would a cam with 114LSA been better considering the blower? |
Originally Posted by MILD THUNDER
(Post 3385974)
fixx
9.1 comp and 8 psi of boost :eek: with 93 5 psi max..
Chillers save motors. Period.
Fuel puddling in the intake due to the chiller at idle is easy to rectify. Do not "pump" water thru the chiller, force feed only and for added idle quality, run a 4-AN feed from the rear corner of the intake manifold where it blocks off the water passage to the rear of the chiller. Warm water will flow reverse direction thru the chiller at idle helping fuel atomization until the force of water from the pick up once under way stops it. I do not have any fuel puddling issues what so ever. |
Originally Posted by Airpacker
(Post 3385987)
Fuel puddling in the chillers at idel is easy to rectify. Do not "pump" water thru the chiller, force feed only and for added idle quality, run a 4-AN ffed from the rear corner of the intake manifold where it blocks off the water passage to the rear of the chiller. Warm water will flow reverse direction thru the chiller at idle until the force of water from the pick up once under way stops it. I do not have any fuel puddling issues what so ever. Packer where he lives they bump up 10 jet sizes and leave the coolers on the bench in waukegan .. LMFAO and hey our Hawks kicked some canuck azz BIG Daddy :lolhit: |
Originally Posted by RunninHotRacing163.1
(Post 3385980)
leave them chillers on MILD and plumbing them like you say no water till underway is correct and she'll idle fine :drink:
I dont have much experiance with the chillers, as far as how much more you can push the envelope with them, vs not having them. I myself, without them, would run 4lbs max on that setup with the 9:1 and iron heads. According to the BDS final compression chart, 9:1 static with 8psi =about 13.9 Final. They suggest no more than 12.4 on pump gas. Which would mean 4-5lbs of boost. Where the chiller factors in, I dont know. :drink: |
How deep are your buddy's pockets and how long does he want these motors to last?
Safe way is to start 4-5psi and adjust up from there. If he is a balls to the wall guy that always has to be fastest I doubt he will take that approach though. Also if his drives are Bravos that is another consideration, its always nice to have reliability |
I am running 4-5psi on my 502MPIs with B&M blowers. I run the 93 octane fuel. Plenty of "go" with long term reliability as well.
Originally Posted by rgrgoog
(Post 3386079)
Right on top
Not getting into any debates but here is my opinion.
The 8-71's at -15% won't make any real heat to warrant chilling and losing idle quality. If it had a 256 blower with a higher rotor speed I would say chill it. BTW, what kind of boat are we dropping them in? Is this a weekend pleasure boat, Jet or I/O? Also what size heads? |
Fixx
Originally Posted by Back4More
(Post 3386128)
(Post 3386117)
Right on top
(Post 3386117)
Right on top
I,m with bfm. 4lbs of boost, no chiller, and no thermostat.
(Post 3386128)
The 8-71's at -15% won't make any real heat to warrant chilling and losing idle quality? And yes, the injectors are on top of the blower. PS, as to the original question, I run 7psi but only 8.2 SCR. |
(Post 3387251)
What "loss of idle quality" are you talking about? My blown/injected/intercooled 509 will idle until the cows come home.And yes, the injectors are on top of the blower.
PS, as to the original question, I run 7psi but only 8.2 SCR. thats just cuz they wuz'nt built in wakeegan Illinois LMFAO :eek::lolhit: |
Fixx
(Post 3387282)
My blown/injected/intercooled 509[B] will idle until the cows come home :drink:
thats just cuz they wuz'nt built in wakeegan Illinois LMFAO :eek::lolhit: B ----- Bashing :lolhit: |
(Post 3387251)
| All times are GMT -5. The time now is 12:03 AM. |
