engine mods to a 502 BBC expected H.P gains?
I have a 1993 502 BBC motor, what kind of gains should i exspect with these engine mods? the stock 502 is 415 to 420 H.p I dont have spicific part numbers for the up grades just wondering if I did these changes what should I gain from It.
1) Lighting stainless steel exhaust headers 2) edlerbrock intake 3) stock 850 cfm holly 4 barrel carb 4) com cam 5) roller rocker ( valve job also) 6) HVH 2" carb spacer 7) stock ignition (spitfire omc) |
With out knowing what the cam grind is a horsepower guess is impossible. The Headers are most likely good for 20 hp on a stock engine, intake 5- 10 hp, carb spacer could do anyting from +15 to -15 but on a mostly stock engine I doubt it will do much.
Originally Posted by intimidator
(Post 3390160)
| All times are GMT -5. The time now is 11:15 AM. |
