Tapping/ticking noise
#32
I would replace exhaust gaskets first, then take to mechanic if necessary...f.y.i Just because your mechanic charged you a staggering 800 bucks to winterize your boat does not necessarily mean that he did a quality job.
#33
X2...Exhaust gaskets first! Listen to Griff and pacalim
#34
BTW, those compression are terrible if they are even close to correct. Those would be what I would expect to see on a 500+ hour engine.
Replace the exhaust manifold gaskets, run the engine up to temp and then repeat the comp test.
#38
Replacing the exhaust gaskets isn't easy!! There seems to be one bolt towards the stern which is blocked and acts like a swivel (kind of a good thing)...problem is the power steering hose won't allow the manifold to go up more than an inch...running out of time today but I'm making headway.
Griff--I agree with you on those compression numbers. However, I have full power so something isn't adding up right.
#39
Ok, well I replaced both exhaust manifold gaskets and both riser gaskets and ran the boat...the problem remains! Its clearly metal on metal (pushrod, rocker, lifter would be my guess). I pulled the valve cover on the port side but havent pulled it yet on the starboard...If the intake has to be pulled Im probably just going to take it to a shop!! This sucks because I really enjoy working on the boat but just feel Im getting past my comfort zone.
#40
Nothing wrong with going beyond you comfort zone, Thats how we learn. Besides its only a v8 engine, been making them for over 100 years and millions of them out there can't be to serious. Sounds like you were right valve train. Let us know what you find, I had similar sound 'not that loud' I pulled valve covers and saw nothing out of norm. friend of mine had strange sound coming from engine compartment and it ended up to be a alternater bolt that backed out and was hitting fins on alternator.
