-   -   Need help with drive height (https://www.offshoreonly.com/forums/general-q/252527-need-help-drive-height.html)
Brian Garcia 04-30-2011 10:04 AM
Hello boaters, I have a 28 saber that I plan to install a pair of bravos and stellings 12in setback boxes. I'm not sure were to put the propshaft in relation to the bottom of hull? Thanking you in advance brian.
jeffswav 04-30-2011 10:14 AM
Seems like most guys with boxes have the propshaft centerline 3.5" to 4.5" deep. I have a post on this with a ton of feedback, I will pull it ttt for you. Feel free to post input there.
Brian Garcia 05-01-2011 06:53 PM
Jeff thank you for reply. I not sure how to find your post.help! Im new at new at this stuff.
jeffswav 05-01-2011 08:03 PM
I pulled it to the top a couple of days ago in the "drives section"
BenPerfected 05-01-2011 09:00 PM
30' Scarab w/Bravos on Stellings boxes. The propshafts are about 2" below the bottom. It is reasonable getting on plane with B1 props. What HP will you have and what is the MPH are you expecting?
Brian Garcia 05-02-2011 01:02 PM
H.p.450 BBC twins 28 Saber . On a twin setup when you measure with a straight edge is it at the keel or directly in front of the drives? Thanks
BenPerfected 05-02-2011 02:17 PM
Measure directly in front of the drives. One other dimension to check would be the "new" clearance between the flame arrestor and and the engine hatch.
Brian Garcia 05-03-2011 02:38 AM
The engine hatch cover was going to have to modified someday. I have blowers and intercoolers that I plan on using when the time is right. Just going to use a carb intake setup at first. Even the stelling exhaust manifolds have elbows that are taller then most .Don't like losing the sun pad!
