Single or twin fuel usage?
I just picked up a different boat and I'm trying to decide if I'm going to keep it or not. I currently have a Formula 242 with a 530 hp N/A BBC. The boat I just picked up is an '89 Formula 292 SR1 with stock 454 Mags. My question here is how much worse the the 292 going to be on fuel? I know that the 292 is going to have more room and ride better, but I don't want to sell my 242 only to find out the 292 is going to break the bank with fuel usage. Also anyone that is familar with the 292, what is the top speed of this boat?
I dont know but I researched this well before I bought twins. Everything Ive heard is that 2x454's will suck more fuel than a single 502/525, but not by much. One draw back is your always going to have maint times two. But if one engines breaks you would still have one left and wouldnt be stranded and or paying a boat load for sea tow. Also 454's are cheaper and parts are more readily available than anything else.
16 mouths to feed instead of 8, it's a no brainier over here.
My 30' twin 425HP boat uses less fuel at cruise than my single 600HP did. Just depends on the boat / motors. WOT, it will certainly use more.
Originally Posted by Greenkeeper
(Post 3393529)
Originally Posted by RT930turbo
(Post 3393538)
You will use a bit more but not double, keep in mind your also pushing a heavier boat, which would be a bit more either way.
With twins you can cruize at a lower rpm and less load on the motors, which is a savings, I have seen 2 mpg average cruising in the mid 40 range. |
(Post 3393538)
If my decisions about engines and HP where made on fuel usage I would get out of this sport or hobby whatever you want to call it. Try a sail boat I hear their really good on fuel consumption.
Originally Posted by fireboatpilot
(Post 3393920)
| All times are GMT -5. The time now is 09:32 AM. |
