Distributor Gear Failure on 454 Mag EFI
#205
I’d put some dye in the oil and use a UV light to verify where it’s coming from. I thought my oil filter pad was leaking but the dye showed a thin trail of oil coming from a fitting above it and pooling there. The dye and light can both be found for under $15 total.
#206
#207
I've had a friend or two use jasper sbc long blocks and never had any issues. About all I can say though. Michigan motorz evidently might need some assembly training. Regardless you got it fixed. Did you prime the engine oil pump prior to installing engine?
#208
Michigan Motorz is clueless. One example alone -- Hell they were selling MEFI 5 marine Inboard engines listing them for sterndrives drop in, plug and play installs. Little did they know all the I/O installs where in for problems. Walmart marine pricing but have no tech info nor that knowledge period.
#210
what's wrong with oil pump?
