Like Tree11Likes
Distributor Gear Failure on 454 Mag EFI
Old 10-04-2017, 06:35 PM
  #31
SB
Trade Score: (1)
It's a hard read, so I just threw something that has happened against the wall.
SB is offline
Old 10-04-2017, 06:36 PM
  #32
My Boats: 290 Aquasport tournament master
Quote:
Originally Posted by veloc410 View Post
oh. All intact. Gear still on distributor shaft. Maybe just a broken split pin on the gear. It's a shear pin goes thru the shaft and gear
Wow maybe u are right and its broken pin on the distributor gear. I will check it!
caldera is offline
Old 10-04-2017, 06:39 PM
  #33
veloc410's Avatar
My Boats: 2001 velocity 410
Quote:
lol post some pics like he said. The gear could be spinning or something wrong at top of distributor
veloc410 is offline
Old 10-04-2017, 08:27 PM
  #34
I buy cam with display in home depot and going to see what's going inside... Checked distributor second time, pin is on place.
caldera is offline
Old 10-05-2017, 01:13 AM
  #35
My Boats: 1967 34 Hatteras summer house. 2000 Crownline 248ccr her boat. 79 Pantera 24 Sport.
ok, this is outdrive boat, correct? you need the pan essentially off to get timing cover off. if you have a car cherry picker, you can get it up enough to get pan, timing cover, and rotate motor till cam comes out. but if this is the hard cam gear, chances are cam is ok. just eats every dist gear that is softer. what gen motor? might be able to shine flashlight down distrib hole and crank motor to check if gear is ok, and turning. but if pin breaks, it retards cam 4 to 6 extra degrees, till the bolts let go.
dereknkathy is offline
Old 10-05-2017, 04:18 AM
  #36
Quote:
No sterndrive. Its straight shaft thats why i hit bottom.
caldera is offline
Old 10-05-2017, 06:12 AM
  #37
Ok, looked at pics of your boat. You will have a very hard time lifting that motor yourself. Weight for block-heads-intake is about 700 lbs. 900 with trans still attached. Engine is dead center in the boat. You need a boom truck to lift engine AND you need to replace or repair the 1 prop you used as a depthfinder. Props are not very good depthfinders. This boat has to come out of the water at a marina that can lift the engine out for you.
Old 10-05-2017, 06:33 AM
  #38
Thanks. I have a same plan. In Marina they have big forklift so it will be very easy to pull out engine .
caldera is offline
Old 10-05-2017, 06:40 AM
  #39
Start looking for people who can repair that prop now. You don't need to pull the boat, send prop off, repair engine, and still be waiting for the prop to be done...
Old 10-05-2017, 06:03 PM
  #40
veloc410's Avatar
Start looking for people who can repair that prop now. You don't need to pull the biat, send prop off, repair engine, and still be waiting for the prop to be done...
do you think it's the timing chain?? Ouch.
veloc410 is offline
dennis r
0
04-28-2008 06:55 PM
blown formula
31
06-10-2003 06:59 PM
Dave1972
10
09-25-2002 09:44 AM
checkmate981
Checkmate
1
05-06-2002 11:25 PM
checkmate981
4
02-02-2002 01:45 AM
