-   -   Bolt removal - bellhousing to transom (https://www.offshoreonly.com/forums/general-q/252917-bolt-removal-bellhousing-transom.html)
handfulz28 05-05-2011 09:19 AM
I see from old threads these things have a tendency to rust/corrode to a sleeve in the transom plate. So if I can't break these loose, and confirm I haven't broken anything where the nut is captured underneath, then that's what I'm facing? So Plan B would be trying to separate the bellhousing from the block?
Volvo uses studs in this application, I think I'd put it back together that way, if there's room.
blue thunder 05-05-2011 10:11 AM
Put a hoist on the engine and lift the engine weight off the transom assembly. Then try to back the bolts out.
