Originally Posted by doctor_ratz
(Post 3396019)
...Seems like the correct answer is no by pass in the nipple, and plug the one on the oil filter pad...
I had my mechanic tap it. Use a filter with built in by-pass and anti-siphon valves to address the "oil starvation issue". I use a Baldwin B279. |
Originally Posted by dogturd21
(Post 3396111)
I am only slightly familier with this issue, but the question in my mind is: if the valves are incorrect, can this be fixed without removing the engine ?
I would not be able to plug or replace the bypass in the boat. It woul dbe impossible.
| All times are GMT -5. The time now is 02:22 PM. |
