-   -   Back flow valve for innercooler (https://www.offshoreonly.com/forums/general-q/253244-back-flow-valve-innercooler.html)
Advantage 575 05-10-2011 07:53 AM
I currently have my innercoolers fed from my sea strainers, one for each motor. Stainer's each have two water feeds, one from the outdrive, the other from a transom pick-up. The stainer sits on the chine shelf which is probably just above or right at the water line. My question is at idle will the engine be starved for water because it will suck the water from the innercooler until emptied? My water pump is a two stage pump that both stages feed the motor. Do they make a back flow valve that i can put on the innercooler feed line? Line is 1 1/4 hose. Innercooler is a Whipple MOAC.
Thanks,
Velocity Vector 05-10-2011 08:40 AM
The MOAC doesn't need water flowing thru it when ideling. As long as water is flowing out the exhaust you should be fine.
Advantage 575 05-10-2011 09:06 AM
I agree with that, but will the engine two stage pump suck the innercooler dry at idle then allowing air into the engine instead of pulling water from the pick-ups? Path of least resistance for water to the engine i believe is the innercooler plumbing
Airpacker 05-10-2011 11:35 AM
why not just use the drive pick up to feed the cooler and the hull pick up to feed the motor?
Velocity Vector 05-10-2011 12:00 PM
Agree
Advantage 575 05-10-2011 08:42 PM
That was my original plan. But the drives are IMCO SCX's and they stated that with the internal drive cooler, the drives should be connected to the pump. That way they will always have water through them to keep them cool, especially after a hard run then to idle. Anybody knows who makes a small back flow valve for water? I have on each on the fuel lines, made by aeromotive, but i haven't seen anything for water.
JRider 06-11-2012 07:45 PM
Dug this thread from the dead. I am looking at using a checkball type valve for the same purpose. I and thinking I will T off the drive intake line and install a checkball right after on the way to the innercooler. My thought is that it will be force feed at speed and will not starve the motor either. Not sure that it matters but the pickup slot is huge in the SC lower. Transom pickup is a problems because it is a pod type cat and the sponsons are notched by the transom. Anybody know of anyone doing this?
