How to check fluid levels??
Whats the preffered way to check the various fluid levels in your boat? ie Engine Oil, Trans fluid, power steering, trim tab, etc.
Should the boat be floating in the water? Should it be on the trailer with the engine level? If anyone knows how boats are set up to have their fluids checked please shed some light. |
Originally Posted by TC G
(Post 3401473)
Check oil level with the boat in the water. It can vary by a 1/2 quart from the reading on the trailer.
None of the other fluid readings will change much from the trailer to the water. |
Originally Posted by Griff
(Post 3402058)
Thanks Griff
| All times are GMT -5. The time now is 12:07 PM. |
