-   -   Anyone running a low water pressure sender? (https://www.offshoreonly.com/forums/general-q/25351-anyone-running-low-water-pressure-sender.html)
kook 05-29-2002 06:46 AM
Looking at installing a low water pressure sender and idiot light. Have both raw water pump and circulating pump. Wondering how to go about doing this - looking for advice.
The idea here is to catch a water blockage problem immediately, rather than relying on the water temp gauge, which alters you to the problem well after it has started. I DO have a water pressure GAUGE now installed - even better than just the H2O temp gauge alone, but this idiot (me) needs an idiot light as well............. could not find a Gaffrig "Redline" water pressure gauge (with built-in idiot light).
thanks,
Mark
FloridianSon 05-29-2002 02:48 PM
If you are like me and have through transom exhaust forget the buzzer, hook it to the horn,then you might hear it:D I have block water temp.raw water pressure,and exhaust water temp.only had one water related problem and the exhaust showed it first and caught it before motor even came up:cool:
rbtnt 05-29-2002 11:52 PM
Great idea.
I installed water pressure guages and low pressure switches on my transom with a hoses to the blocks. The low pressure switches are connected to Gaffrig idiot lights on the dash. It saved me once when I had a water hose come loose. The lights stay on at idle speed, but go out as soon as I get off of idle.
kook 05-30-2002 09:56 PM
Originally posted by rbtnt
Great idea.
Where did you get the low pressure senders, and what are they set for (PSI)? How's it wired - always open circuit unless the water pressure is below the sender's switch point?
-mark
rbtnt 05-30-2002 10:18 PM
mark,
My sendors are open unless pressure is below 4 psi. Wired one side to ground and the other side to alarm light, other side of alarm light is wired to +12v.
I think they came from NAPA. Rex Marine has the sendors, they use them for low fuel pressure alarm.
randy
rbtnt 06-02-2002 10:13 PM
canada jeff,
I put a barb fitting in place of one of the block drains on the side of the block. I did it on both motors, but on different sides and both read about the same.
rbtnt
