Is 212* rating for Fragola Push-Lok hose sufficient for oil cooler line?
I redid my fuel lines using the Aeroquip AQP SOCKETLESS hoses and fittings 2 years ago and have had zero problems with it. 300f & 25psi. It looks good and was easy to work with.
http://www.summitracing.com/parts/AER-FCV0815
FWIW, I also did a lot of research on oil lines, coolers, etc. I had a lot of people tell me that I might encounter problems running the stock Merc oil cooler and lines with a high output engine. I built a fairly warmed up 489 - square port, Holley 800, Lightnings, and hyd roller with specs similar to the 500 EFI cam. I retained the stock Merc combo oil / PS cooler, but to help with flow I eliminated the stock Merc lines and fittings and moved the oil filter down to a thermostatic sandwich adapter on the block. I figured oil flow would be my biggest issue, and the #10 AN fittings should help with that. My oil temp gauge generally hangs around 185* when running it easy, and it goes as high as 220* if I am deep into the secondaries and running above 4000 RPM for several minutes. I haven't really leaned on it full throttle yet for any extended length of time, because I just now got over the 15 hour mark on the engine and have not done any plug readings. It's not my style to go WFO "poker run style" for extended periods anyway. Right now, I am confident that my setup will keep my oil temps under control. Just thought that bit of info might be useful for someone else who is putting together a mild - warm build.
Jason, I ended up going with a SS braided hose and AN fittings - can't remember the brand, think it was Aeroquip. In a #10 size hose, they are a bit of a ***** to work with, especially if you have a tight curve to make.
Good info on the oil system too. I have bellhousing coolers and I think with the line upgrade should be pretty well set.
Thanks again!
Well I guess you did it with stainless so it doesn't matter. But, Fragola's push on series 8000 is rated at 300 degrees. It has a black nylon coating on it and is very light weight as well.
