Originally Posted by Raylar
(Post 3409751)
Uncle Dave:
Those are excellent numbers and results from a 406 small block! If this boater can get at or close to those numbers from his small block using your specs and examples, he will be a very happy camper! Learn and profit from someone else's excellent design and results and you will be way ahead, don't re-invent the wheel! Best Regards, Ray @ Raylar I have to give the credit for the combo to the engine builder. An old drag racing guy named Dick Gazan thats been doing it since I was forming eyelids. Your LSM 550 is an awesome package I would love to have the money to buy! UD |
Originally Posted by HaxbySpeed
(Post 3409957)
No it was great down low and idles strong. That dyno didn't have enough water supply for long pulls. The 406 is a great combo the 434 works good too. I like small blocks :coolcowboy:
Im guessing it needs race gas and is setup for car though. I asked my builder about a 430+ setup and he told me they make great power but have issues with wear which I thought was strange, but recited stuff about getting there with stroke causing rod angle issues. I was originally interested in 454 SB short block with my heads, but stuck with my old "garage special" 406. UD |
Originally Posted by Uncle Dave
(Post 3409414)
Lets back up a bit.
What kind of drive system in a "stinger 202"? How much does it weigh? If you get past 70-75 with a heavy boat it want to run anymore without hydraulic steering - have you provisioned for that? What kind of HP and torque are you expecting to get at what RPM range. what kind of exhaust are you going to be running - the factory stuff will flatten your engine and choke it so you will need a good aftermarket exhaust. Aluminum vs Iron heads will either save you possible detonation if you get a tank of lousy gas (always a possibility with a boat) r let you run more static compression to begin with. If you have the short block apart you might as well build in some bigger cubes. I have much experience with small blocks and boats. Uncle Dave Im not sure what the boat weighs... but I towed it home at 80 mph behind a 4cyl toyota tacoma.. And it was lifting off the trailer. So, lets just call it light... I will be dealing with the drive system later, it had through hull exhaust and I will be looking for higher flowing manifolds later on in the project. I have a displacement limit on my lake at 360Cu in.. Id rather pay a little extra and get an all new head than deal with digging parts out of boneyards that have been well used up and need a lot of work done to them. So let's limit this to aftermarket Iron heads.. 165's might be a tad small and 230's are probably too big. Am I wrong on this? |
(Post 3410583)
Wow thats a nasty piece for sure! Big fun.
Im guessing it needs race gas and is setup for car though. I asked my builder about a 430+ setup and he told me they make great power but have issues with wear which I thought was strange, but recited stuff about getting there with stroke causing rod angle issues. I was originally interested in 454 SB short block with my heads, but stuck with my old "garage special" 406. UD 434 right it's no problem. For forced induction I like the 406 better. |
Originally Posted by zerotact
(Post 3411112)
The boat is quite a project.. and I am taking it one step at a time. from the inside, out
Im not sure what the boat weighs... but I towed it home at 80 mph behind a 4cyl toyota tacoma.. And it was lifting off the trailer. So, lets just call it light... I will be dealing with the drive system later, it had through hull exhaust and I will be looking for higher flowing manifolds later on in the project. I have a displacement limit on my lake at 360Cu in.. Id rather pay a little extra and get an all new head than deal with digging parts out of boneyards that have been well used up and need a lot of work done to them. So let's limit this to aftermarket Iron heads.. 165's might be a tad small and 230's are probably too big. Am I wrong on this? I wouldnt expect any real gains until you do the exhaust manifolds with a quality aftermarket unit - so Id try to save up and time it so they both get done. ( SB marine exhaust is one of the harder components to find used) I ask about the drive because Im suspecting its an i/o which means the unit needs to idle at around 800 RPM which means no big cams/ head ports or runners. UD |
| All times are GMT -5. The time now is 03:15 PM. |
